05' 700 efi gear indicator problem
Old Feb 21, 2005 | 04:45 PM
Wally23's Avatar
Default 05' 700 efi gear indicator problem
Has anyone else had this problem? On my 05’ 700 EFI when I shift into low the indicator on the dash says the machine is in neutral and the awd won’t work, but the machine is definitely in low. I guess the awd won’t work because the indicator thinks the machine is in neutral. When I shift into high the dash says I’m in low and the machine is really in high. Park, reverse and neutral work fine it’s just when I shift from neutral to low it says I’m still in neutral. I see the shift linkage goes back to the transmission and there are some wires that come out of the transmission just under where the shift linkage connects to. I’m going to bring it to the dealer I was just wondering if someone else has had this problem and had an easy fix for it.
Thanks.
Old Feb 21, 2005 | 09:19 PM
elkbow's Avatar
No problems here. Sounds like a simple adjustment to the linkage....
dave
Old Feb 21, 2005 | 09:38 PM
Wally23's Avatar
dave
That’s what I originally thought, but I get the right gear it’s just that the machine thinks it’s in a different gear. I’m thinking it’s some sort of electrical problem. When I take it in I’ll asked the dealer what the problem was. Hopefully I won't have to wait forever to get my machine back. Thanks for the reply Dave.
Old Jun 12, 2006 | 01:35 PM
AtomicShoCKer's Avatar
Hey Wally
Any update on this? What was the problem? What was the fix? I have a buddy with the same problem and hoping to find an easy, CHEAP fix.
Thanks
Old Jun 12, 2006 | 02:32 PM
Wally23's Avatar
Originally posted by: AtomicShoCKer
Hey Wally
Thanks
It was still under warranty so I took it to the dealer. I can't remember exactly what the problem was but the dealer said it was the third or fourth machine that they had the same problem with. I believe it was some sort of electronic thing that connects to the shift linkage. I know I wrote the down the name of the part but that was over a year ago. I'll look tonight and post if I find it.
Old Jun 12, 2006 | 02:53 PM
400L4x4's Avatar
Sounded like a sensor.
Old Jun 12, 2006 | 05:12 PM
gates59's Avatar
It is your gear shifter sensor. If you folow the rod to the trans. you will see a small black sensor with a few wires coming out of it.
toonces
Oct 16, 2019 12:11 PM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
ranvette
Jul 4, 2015 06:13 PM
