lt 80 starter question
Old Feb 22, 2005 | 01:10 PM
joker258's Avatar
Default lt 80 starter question
i have a 2001 lt80. the question i have is the kids were riding it it died. the starter wont turn over. i jumped it at the relay & is still dont start. if the motor was seized i would think the starter would at least make a humming noise. is the any other way to check. also is the a secret of getting that starter out of there
thanks
Old Feb 22, 2005 | 02:01 PM
LT80's Avatar
LT80 Expert
Stand the machine on the rear bar and jump it at the starter.
To remove the starter, you most first remove the big bolt that holds the motor in. Raise motor.It's a tight fit. [img]i/expressions/face-icon-small-smile.gif[/img]
Remove the rubber on top of the fan cover (right leg) and see if you can turn the motor over with the fan using your finger.That'll tell you if the motor is siezed.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Feb 23, 2005 | 11:01 PM
joker258's Avatar
ok i jumped starter at the starter and it works. i swapped relays that is by the battery with a known good relay. still doesnt work. jump the connection at the relay still doesnt work. where shoud i check next. is it in the brake switch or the on off switch. or is it a wiring problem
Old Feb 24, 2005 | 11:44 AM
LT80's Avatar
LT80 Expert
I've found the push button to be a problem before.
Old Feb 24, 2005 | 12:32 PM
joker258's Avatar
when i push the start button i can here the relay click by the battery. also i jumped it at the relay & wont start
Old Feb 24, 2005 | 05:07 PM
RacerDad's Avatar
Two problems that I have had are:
-Circuit Breaker under rear fender/Seat can be tripped?
-Black ground wire that is attached to engine needs to be grounded properly...
Old Feb 26, 2005 | 04:02 AM
confusedbuyer's Avatar
make sure foot brake safety switch is getting pushed in. check fuses. check for pinched or loose wires. good news is, your starter is working.
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 19, 2015 10:13 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
mudpig79
Jul 13, 2015 03:31 PM
