what shims for shim unders??
Old Feb 24, 2005 | 09:10 PM
shmee's Avatar
Default what shims for shim unders??
thank you! and is it diff than the woods springs and shims. thanks
Old Feb 24, 2005 | 11:28 PM
shmee's Avatar
well fine. it looks like i get them at the kawi dealer right? anyone??
Old Feb 25, 2005 | 12:00 AM
DuneMe's Avatar
Not sure about yours, I run the Pami set-up so, a little different but. . . if you have a knife sharpening stone and the clearances aren't enough, you can work the shims on the stone for a while to thin them out.
Old Feb 25, 2005 | 07:44 PM
Hightower's Avatar
I have the Web shim under kit, don't remember exactly but seems like 13mm diameter shims but can't be certain....but yes you can get them at a kawi dealer, the shims Web uses are standard issue for kawi street bikes I'm told.
like duneme said, you can grind the shims thinner if that's the direction you need to go...I have a local machine shop stick them on a magnetic base under a surface grinder and take them down to whatever needed. have them grind a little off both sides, to stay in perfect parrellel. they charged me less than the price of new shims, $10 for the set of all 4.
Old Feb 25, 2005 | 09:53 PM
shmee's Avatar
thanks guys, its for a ds we have in the shop. i havnt messed with those yet.
hueby
Nov 6, 2015 11:34 AM
Whitelx1
Oct 2, 2015 10:55 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
Elkaholic
Sep 6, 2015 02:44 PM
toonces
Sep 5, 2015 01:14 PM
