what shims for shim unders??
I have the Web shim under kit, don't remember exactly but seems like 13mm diameter shims but can't be certain....but yes you can get them at a kawi dealer, the shims Web uses are standard issue for kawi street bikes I'm told.
like duneme said, you can grind the shims thinner if that's the direction you need to go...I have a local machine shop stick them on a magnetic base under a surface grinder and take them down to whatever needed. have them grind a little off both sides, to stay in perfect parrellel. they charged me less than the price of new shims, $10 for the set of all 4.
Elkaholic
09-06-2015 02:44 PM
