Cam for 200x
Old Feb 25, 2005 | 11:00 PM
200xfan's Avatar
Default Cam for 200x
Hi,
I was thinking of putting in a XR200R cam in my 200x.. What year of XR 200R cam should I get. Open to more cams.. I don't want to rise compressoin yet .. Just want alittle more power .
Oh also what is a good gear ratio to run for mid-top end speed please tell me what gears to get.
Thanks
200xfan
Old Feb 25, 2005 | 11:32 PM
tdup's Avatar
all years except 84 and 85. You can order a new one at servicehonda.com part # 14101-446-000 for $57.36 and that is for a new camshaft. I just ordered a new one for myself yesterday. I do have a good used one but I am really fixing my x up and desided to go with new. I am building a back-up motor and my old one will go in it. My xr bottom end will be here in a few days for my back up motor. I wont be in a hurry getting it together since it is a backup motor. I may do a tech article with pics on how to convert for the forward kick for everyone.
Old Feb 26, 2005 | 02:48 AM
KNOWSALOT's Avatar
The Facility
You will need more than just the camshaft itself.
DO NOT FORGET THE CAM BUSHING AND THRUST WASHER!!!! These pieces are not included with the camshaft.
Too many people throw in new cams without replacing these parts. If you go with a new cam, get a new bushing and thrust washer. If you go used, get the bushing and thrust washer THAT WAS USED WITH THAT CAM!!
I know I am using alot of CAPS here, but trust me, the $30.00 for those two parts are required if you are planning on building this engine right the first time around.
I know some who have never done this and they have never had a problem.....but I have seen it go the other way just as often. To me, it isn't worth the risk.
Patrick
Old Feb 27, 2005 | 10:35 AM
short4stuff's Avatar
knowsalot .. should the rockers be changed too? .. I heard it will wear the cam fast if used rockers are used with a different/new cam.... true?
Old Feb 27, 2005 | 03:00 PM
KNOWSALOT's Avatar
The Facility
short4stuff,
Thanks for bringing that up because I din't think about the rockers at all when I made that post....and that coming from someone who has never installed a new cam on these old engines without installing new rockers with the bushing and thrust washer.
There has been a time or two that I have used the old rockers with a new cam, but only with those that are in great shape.
The rocker contact area with the cam is important, but no where near as important as the actual "riding" areas of the camitself, and that was what I was getting at in that post.
New rockers from Honda are expensive, but a good quality set of aftermarket ones can be bought through anyone using J&M as a supplier for aftermarket parts.
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
88Warrior
ATC 3-Wheelers
Aug 7, 2001 07:27 PM
hrc200x
ATC 3-Wheelers
Feb 7, 2001 08:46 PM
bigmanm
Jun 28, 2000 10:34 PM
200X
ATC 3-Wheelers
May 24, 2000 10:47 PM
