new clutch --- hard to shift gear lever
Old Feb 26, 2005 | 08:25 PM
bigbird650's Avatar
Default new clutch --- hard to shift gear lever
just put in new clutch and the woods 60% springs the gear lever is hard to shift up and down-- i adjusted to spec-- when i put it in first it acts like im not pulling the lever in far enough and pops into gear--what am i doing wrong????
Old Feb 27, 2005 | 01:57 AM
DuneMe's Avatar
How tight did you put the springs in at? Sure it was 89 INCH/#???
Once warm does it do it?
When the bike is cold I get a pop into 1st gear.
Old Feb 27, 2005 | 04:07 AM
bigbird650's Avatar
i tighten them at 89 inch lbs when i got it out and seen it was hard to shift i brought it right back to the garage I didnt want to mess up something so i would say it wasnt warmed up all the way it has never done that before is it because of the woods springs?
Old Feb 27, 2005 | 12:50 PM
naturalite's Avatar
Mine is allways alittle stiff when its cold. One it warms up its good to go. Doesn't mater if it's 10w40 or 20w 50
Old Feb 27, 2005 | 03:41 PM
Hightower's Avatar
springs shouldn't have anything to do with it, when you pull the clutch lever you are disengaging the clutch and compressing the springs, once the clutch is pulled the springs aren't doing anything at all except putting tension on your hand.
did you soak the new fuibers in oil prior to install? I mean really soak them, not just wipe a film on them? if they are not soaked well, they can cause too much friction and stick to the plates even after you pull the clutch lever in to release the pressure plate, cause a "popping into gear" scenario, and also cause premature wear of the new disks.
if you soaked them well, and the pressure plate is truly disengaging when you pull the lever, then there should be nothing wrong to cause popping into gear other than the ordinary that duneme and naturalite mention.
Old Feb 27, 2005 | 06:53 PM
bigbird650's Avatar
soaked them for a long time put them in straight from the oil maybe do i need to move the little clutch arm back 1 notch i measured it and im like at 69mm think this will help??
KimSJoh
14
Jul 18, 2015 07:20 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
sara durrant
Jul 6, 2015 05:32 PM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
