Carb Help needed and quick
Old Feb 27, 2005 | 02:25 PM
hiofcer's Avatar
Default Carb Help needed and quick
Hi All. I have been tasked with getting my grandfathers 71 Artic cat snowmobile running and up foe sale. It has a 303 Wankle "rotary" engine Like a Mazda RX-7. I got the thing running yesterday for 30 seconds on the second pull after being stored since 1988. But I believe i'm having a bit of carb troubles.
First I replaced all fuel lines from the tank to the carb with new clear hose. I see the fuel making it to the carb but the carb does not seem to pull the fuel to the engine.
if I removed the inlet hose to the carb and used an oil can to squirt the fuel in the carb the engine will start. As soon as I put the hose back on it wont start even though I know I'm feeding the carb. So the fuel is not making it to engine. Why? where do I start.
I need to have this running by next weekend. There is a show in Isanti MN were I want to sell the snowmobile. And my grandfather really needs as much money as he can get out of this sale. So it has to run.
The carb is a Tillotson model HL and I downloaded the schematics from the web but I have no clue where to start.
Thanks far all your replies.
Old Feb 27, 2005 | 03:38 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
The carb is definitely gummed up from all the time sitting. It needs to be taken apart and cleaned. I use carb cleaner and then compressed air to clean all passages. Have you ever cleaned a carb before?
Old Feb 28, 2005 | 01:54 AM
hondabuster's Avatar
Its probably the pilot jet which is plugged, it controls the fuel in the idle circuit.
Have you tried starting at 1/4 throttle? This will bypass the idle circuit and if it starts and runs at 1/4 throttle and dies once you go back to no throttle, it confirms the idle circuit is plugged.
Sounds like a unique sled. Whats going on in Isanti? wheres the show at? I dont live far from there.
Old Feb 28, 2005 | 07:10 AM
hiofcer's Avatar
It's the artic plunge at Sunsets resort on Long Lake. They are going to have Vintage Snowmobile races. I thought this might be a good place to sell the snowmobile.
Thanks for the replies. I'll dig into it tonight and report back.
Old Feb 28, 2005 | 09:04 PM
hiofcer's Avatar
Well I think the carb has a ruptured fuel pump diaphragm. It runs great as long as I continue pushing the primer.
Old Feb 28, 2005 | 09:35 PM
jaggers2e42's Avatar
yeah i had carb trouble not to long ago on my quad which had been setting for a few months.i just took the bowl off and what ever rubber gaskets that were good,the floats and i just stuck it in a bucket of carb cleaner over night took it out blew air threw all the jets now it runs like a new one. it's amazing what letting something sit around will do to it.
neilbedwell
Nov 10, 2018 11:02 AM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
Timjunior
Ask the Editor
May 28, 2015 01:09 PM
ragewraps
May 27, 2015 08:07 AM
