speedo problems on 500 ho
Old Mar 8, 2005 | 06:46 PM
polaris700sportsman's Avatar
Default speedo problems on 500 ho
I have a 2001 sportsman 500 ho and the speedometer quite working. I thought it might be a cable but when i took it apart it doesnt have a cable, everything is electrical. Does anyone know if there is a fuse for this, i looked everywhere and cant find a single fuse on the quad. Any information would be appreciated.
Old Mar 8, 2005 | 08:13 PM
SPORTSMAN70003's Avatar
If everything else works but the speedometer needle then its probably your Hall effect sensor and it's down next to your right front wheel. It counts the holes in your rotor. Take it off and clean it and see if that helps. If everything has stoped working in your speedometer then the speedometer probably needs replaced.
Old Mar 8, 2005 | 08:53 PM
The speedometer lights up but the odometer does'nt work either. Do you think it could still be the sensor by the wheel? I took it apart and cleaned it but it still dont work. I guess i will have to get a new one
Old Mar 8, 2005 | 08:58 PM
Does your AWD work?
Old Mar 8, 2005 | 10:42 PM
yes, the AWD works
Old Mar 8, 2005 | 11:21 PM
PolarisTheOnlyWayOut's Avatar
My 500 had the same prob...check all the grounds for the speedometer...that was my prob...somhow i cut a ground...i jsut traced wires and found it...
Old Mar 9, 2005 | 01:50 AM
jimmypsp700's Avatar
If the time meter is still counting and just the speedo needle don't its the Halo sensor most likely.
You can try cleaning it but it probably needs to be replaced, I'm on my third one.
the OEM P/N for my 02 700 is 4010298
go to www.polarisOEMparts.com
they are discounted at around $42 (cheepest I've found).
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
