How do change a rear cv boot on a Sportsman?
Old Mar 12, 2005 | 10:13 AM
Madcap's Avatar
Default How do change a rear cv boot on a Sportsman?
I can do the front ones no problem. Can't figure out how to do the back. How do you get the axle out. The parts book says that there is a clip on the axle. I can't find it.
Old Mar 12, 2005 | 10:45 AM
Billyclub's Avatar
Remove the tire
remove the hub
remove upper control arm bolt from bearing carrier
remove both lower control arm bolts from bearing carrier
tip hub outward and seperate shaft from hub
I believe you need to seperate the shaft from the transmission and that is done by "pulling sharply" on the shaft and it should dislodge from the tranny.
that should allow you to change out the boots.
change both since you have it apart.
Info above is straight out of the service book. Good Luck.
Old Mar 12, 2005 | 10:53 AM
Madcap's Avatar
Thanks.
bzdok1234
30
Feb 23, 2016 01:55 PM
coldnorthpol
Jul 14, 2015 11:22 PM
Shifts
Jul 3, 2015 07:59 AM
VRRRRT
Jun 27, 2015 09:38 AM
blaze_master
May 26, 2015 11:18 AM
