My front fender mounts hit!
Old Mar 17, 2005 | 10:08 AM
SCOUNDREL's Avatar
Default My front fender mounts hit!
I looked at past postings and can't find anyone indicating they have the same problem as I do. DON'T GO THERE !
Anyway what is happening is I put on new front tires 22x8x10's the original was 22x7x10. The added 1" width has caused the tires to rub the fender brackets. Has anyone had this problem and what was done to correct it?
Old Mar 17, 2005 | 10:56 AM
Majorecho's Avatar
8" width will rub, I run the wider fronts for better flotation in the sand BUT I don't run the fenders in the sand either. I don't see a real easy solution because the fender clearance with the frame and a- arms is already very tight. Let us know if you find a solution.
come to think of it, if you replaced the wheel studs with a little longer bolts and then bolted on a nut first and then the tires you could pickup 3/8"-1/2" of clearance.
Old Mar 17, 2005 | 11:23 AM
SCOUNDREL's Avatar
Well if nobody comes up with an answer other then removing the fenders all together then I will design a fitting that will allow the relocation of the brackets from below the wheel.....
Old Mar 17, 2005 | 11:38 AM
JEFFROE's Avatar
pull back on the bracket (bend them out of the way) i had the same problem when i put on the 23" front tires.
Old Mar 17, 2005 | 06:37 PM
SCOUNDREL's Avatar
I came up with a little fitting that I will make at my shop. The brackets will need to be cut below the cross bar about mid way down. Once they are detached the fittings will slid on and they can be rotated to set the fender bracket 3/4" away from the original position. The fitting is out of steel so it can be spot welded or the thru holes can be tapped for 1/4-28 set screws, I haven't made up my mind yet.....
I'll try to put a 3D picture of the fitting on my photo page.......
Old Jun 4, 2005 | 06:13 AM
Dedu's Avatar
Hello guys,I will upload my baja fronth fenders foto project,just wait.
Old Jun 5, 2005 | 06:11 AM
Dedu's Avatar
Hi guys,it's me again...I just put picture in my gallery to tell you what i means.I hope that's what you guys meaning about.I hope i can explain it to you:Cut thos fronth are rear pipe which is holding the fender.drill 2 holes,find smaller pipe and drill2 or 4 holes depeds how big is the tire and put it inside the pipe you cut and done.use bolts to fix it.times you need bigger tire move it up and need street devil gold speed tire(for.ex) put it back to normal level.hope its helps.Thanks and have a nice safe ride.Regards,Dedu
Bratman2
Aug 6, 2022 01:42 AM
carolinabomb
Jul 26, 2015 08:40 AM
RticKwad
Jul 21, 2015 03:00 PM
tporath
Jul 11, 2015 12:31 PM
cSchwartz
Technical and How-To Articles
Jul 10, 2015 08:06 PM
