fitting 27" on 450ES ?lift?
Old Apr 11, 2005 | 02:50 AM
Z1500's Avatar
Default fitting 27" on 450ES ?lift?
I just got my 00 Foreman 450 and the first thing I need to do is bigger tires. To fit 27's and still have fender clearance I want to do a lift too. The stock spring rates seem too soft for my liking so to lift it I was thinking about doing some aftermarket springs like these.- Here
Any thoughts on those?
Next thing is can I put 27's on my stock wheels? My wheels are 12's I just wonder if the width and backspacing works out OK.
What tire? Seems like everyone likes Muddlites but I live in Arizona and we don't get lots of mud. Mostly hard pack dirt and rock crawling.
Thanks,
Old Apr 11, 2005 | 08:16 AM
TRIPLELSTROKER's Avatar
You can run the 27inch tires no problem without a lift. I dont know about with stock wheels, I dont see why not. We all run ITP wheels which are only 7 inches wide and offset to the out side a little. I installed the hi-lifter lift kit on my Foreman. It looked good and actually made it ride better and handle lighter. I assume from the different angle the shocks were in with the kit installed. One day I jacked the atv up in the air in order to remove the front wheels and clean the brakes. I noticed that with the suspension unloaded the cv's were in a bind when you tried to turn the wheels. The wheels actually had to move up and down as the axles turned because the cv's were in such a bind. I removed my kit due to this reason. A 2inch body lift is not worth ruining 700 bucks worth of cv axles to me. The best way to get lift is with the larger tires and that way you actually have more ground clearance under the axles and frame, not just the body. If you lived closer I would give you a great deal on the lift kit if you still wanted it, but shipping would probably be too much. As far as tires go, the mudlites are excellent tires for all types of ground and trails, not just mud. They grip great on slippery terrain such as roots and rock, sand , mud , leaves, hard packed surfaces, everything you can incounter. I have almost 1000miles on the set on my Foreman and they dont even have the dimples worn out on the lugs yet. There are a lot of good tires out there, but I sure like the mudlites. It would be interesting to try a set of radials one day to see if they were any better of a ride or not. Enjoy your Foreman and ride safe!
Old Apr 11, 2005 | 08:19 AM
One more thing on the mudlite tires, if I ever wear this set out I will go with the 28inchers next time!
Old Apr 11, 2005 | 10:03 AM
hondariderAR's Avatar
thats funny cus im going down from a 28 when mine wear out..28 is too big..u have almost 0 suspension travel with them..u hit a small bump and it just smacks ur fenders..i dont like it much [img]i/expressions/face-icon-small-sad.gif[/img]
Old Apr 11, 2005 | 01:34 PM
Maybe I had better stay with the 27inch tires then. Thanks for the info.
Old Apr 13, 2005 | 11:36 AM
action450s's Avatar
You can fit 27x9 front and 27x12 rear no problems on stock suspension and stock rims. The 450 has 12" rims stock, the older 400 had 11's which would mean youd have to upgrade. 28" tires will require a lift which is hard on the CV's in the front.
Old Apr 13, 2005 | 01:45 PM
deerbuster's Avatar
hey i have a 04 foreman es and i have 27x10 on front and 27x12 on back they fit perfect no rubbing only when you are turning sharp and you hit a big bumb.[img]i/expressions/face-icon-small-smile.gif[/img]
EIF
Apr 20, 2017 07:15 PM
QuadRiders
Oct 22, 2015 04:13 PM
tysonbully
Sep 28, 2015 02:30 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
