What could be the problem???
Old Apr 16, 2005 | 12:31 PM
Vunit's Avatar
Default What could be the problem???
Last night i was riding my quad with some friends and i started noticing this a week ago or so, but it was really bad last, anyway my whole steering stem moves up and down, and every time when i wheelie i feel it and it is buging the crap out of me, i tryied looking and at the bottom there is a bolt with a codder pin in do i mess around with that or what any help with be great thanks!
Old Apr 16, 2005 | 12:43 PM
rolsmojave3's Avatar
yeah..tighten that up...then on the other side tighten them two bolts...that's should do the trick...you can also tighten the upper clamp if it can move forward or back a little
Old Apr 16, 2005 | 09:35 PM
Vunit's Avatar
yeah thanks, i gonna mess around with it tommarow it got too late tonight. But thanks ill give that a try.
Old Apr 16, 2005 | 11:32 PM
mentalmojave's Avatar
Tightening the nut probaly wont do much for ya since the cotter pin prevents it from coming loose in the first place. My old mojave had the same problem. There is a movable bushing at the bottom of the column where those 2 bolts hold that plate to the frame. The slack comes form the bushing being wore. I measured it all up with a caliper and went over to Napa auto parts and they found me a bearing with the same size inner diameter and outer diameter and it only cost $7 and never had trouble with it again. Actually if you do a search you might find the part number for that bearing because I remeber posting it so others could do the same fix.
Old Apr 16, 2005 | 11:37 PM
Click here this is the post I was talking about. Bearing was $15, not $7 It has the measurements for the bearing you'll need.
Old Apr 16, 2005 | 11:39 PM
actually I think I still have that column from my mojave. I still had a few parts that I hadnt gotten ridden of yet. If I do I'd sell you mine and then you wont have to worry about cutting the old bushing out. Let me know.
Old Apr 16, 2005 | 11:51 PM
holeshotz8436's Avatar
ya i'd say mental mojave is right bout this one. my friends honda 300 4x4 does the same thing but he never fixed it and now it lifts up like 1.5 or 2 inches and the bars move 3 inches to each side before the wheels turn and its a saft hazord to ride, lol. but anyway, he took everything appart and the bushings were wasted
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
