New Recon owner questions
Old Apr 19, 2005 | 11:31 PM
liquidplumber's Avatar
Default New Recon owner questions
Hi all
I recently bought a 2001 Recon and have a few simple (I hope) questions
#1 the owners manual says to use SAE 80 gear oil in the rear end I could not
find this at the store. I use SAE 80w90 in my 4x4 would this be O.K to use ?
#2 Owners manual says to clean " engine oil centrifugal filter" and
"engine oil strainer screen" but gives no directions on how to do so
any info would be appreciated
#3 I need a headlight anybody have a part #
#4 Any grease fittings on this bike? if yes where?
thank you
Old Apr 19, 2005 | 11:37 PM
reliv007's Avatar
Whats your size and weight? Why did'nt you get a Rancher?
Old Apr 20, 2005 | 12:01 AM
I am 6' 240 lbs.
my daughter (who I bought the Recon for) is
4'11" 100 lbs. thanks for asking [img]i/expressions/face-icon-small-wink.gif[/img]
Old Apr 20, 2005 | 01:02 AM
Gimpster's Avatar
I can't help with the headlight number, but there are no grease fittings on the sled, the engine oil centrifical and screen filter require removing the front engine cover, the centrifical is the outer cover of the centrifical clutch and the screen is slid into the engine case held in by the engine cover. I would suggest using a hypoid gear oil in the diffy, many gear oils are not GL5 rated and are not suitable for the heated friction built up by the extreme pressure of the hypoid style of ring and pinion gear tooth contact area. I use the Bel-Ray oil myself, but Honda has a hypoid gear oil available. I use these because they are not a thick oil like 80-90, more like a synthetic blend, very easily poured for a 80w oil. Way easier on the machine when used in cooler weather.
----- Gimpster -----
Old Apr 20, 2005 | 07:47 AM
Thank you Gimp
Cole Hadden
Jun 15, 2025 09:05 AM
Hunter100us
Oct 7, 2015 11:46 PM
2007 Grizzley 450
Aug 13, 2015 06:33 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 10, 2015 02:20 PM
