identifying a cyclone cylinder
Old Apr 21, 2005 | 09:42 PM
drlang's Avatar
Default identifying a cyclone cylinder
How can you tell a cyclone cylinder from a regular 250 cylinder? I suppose port size, but without those numbers I don't know. Found one used, but the seller isn't sure either. That would be a nice performance upgrade if it was indeed from a cyclone. Are the casting #s the same?
Old Apr 21, 2005 | 09:58 PM
LSkrabut's Avatar
I am positive the porting is different, I had a 88 trail boss and friend had a 87 Cyclone. Been into these motor before, but a long time ago.
But by merely looking, GL
Check out this site, http://www.polarisoemparts.com/ punch in the numbers off the cylinder.
BTW, Cyclone and Trailboss cylinders are different part numbers per the breakdown on that site.
Another thought, there could of been some porting done from a stock cylinder? Or U could get some porting done anyway.
My TB, I more or less made into a Cyclone motor, CArb, Head and port job. Also had a Cyclone pipe. She sure did scream [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 21, 2005 | 10:02 PM
drlang's Avatar
That's the plan, have a spare head .020 off it, trying to piece the rest together for a sleeper 2x4 with racks and all!
Old Apr 23, 2005 | 02:01 AM
RickRitter's Avatar
Check the intake manifolds . Cyclone has a different bolt spacing . This is the easiest way to tell .
Yes , the porting is different too .
Note -- > Polaris detuned these engines to keep them from wearing out so quick ;-)
Note -- > Stock cylinder and 488 sled piston will go good too .. The intake skirt is a little shorter .
Rick
Old Apr 23, 2005 | 05:45 PM
drlang's Avatar
I suppose the manifold would have to have a wider bolt pattern because of the 38mm.
What's this 488 piston business all about? Stock tb cylinder? What is the bore size? and what would I gain?
Old Apr 23, 2005 | 07:09 PM
naturalite's Avatar
good question. does the 488 ofer better performance?
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
