2003 blaster will idle, then no power on takeoff SUGGESTIONS!!
Old Apr 26, 2005 | 08:33 PM
quadrunner2008's Avatar
Default 2003 blaster will idle, then no power on takeoff SUGGESTIONS!!
i got a 2003 yamaha blaster and when you start it up and go to takeoff it stays at the same rev.
Already replaced stator. SUGGESTIONS PLEASE!!!!!!!!!!!!!!!
Old Apr 26, 2005 | 09:01 PM
oldturtle's Avatar
Your problem reminds me of once years ago with a Penton 250 about a 1974 when I had same symptoms, it would start and idle but no power when you got above idle. The problem was my spark arrestor was plugged nearly solid so it could not breath.
If you have been playing with the jetting you could be way too rich on needle or main. You may have left a rag in the carb intake after cleaning filter. I believe the 03 Blaster has Yamaha's TORS (Throttle override system) like the Banshee but not sure. If Blaster has TORS then one of connections could be loose or some other system malfunction. Most Banshee owners just remove the TORS altogether.
Good luck.
Old Apr 26, 2005 | 10:35 PM
Raptorider05's Avatar
make sure your parking brake is completly off or else you wont have any power , but it will idle like normal
Old Apr 26, 2005 | 11:36 PM
Six2notScaredofU's Avatar
I Had the same Problem with my Banshee. it was the Parkbrake switch it was bad so i just cut the wires.[img]i/expressions/face-icon-small-smile.gif[/img]
Jmuddin284
Jan 19, 2026 07:16 AM
Sjrpp
May 2, 2023 03:59 PM
Frisky2050
Apr 9, 2020 11:19 AM
Sjrpp
Nov 15, 2019 09:59 PM
tweeder
Jul 5, 2015 01:57 PM
