2 Stroke engine life
Old Oct 3, 2000 | 08:31 PM
lt250rman's Avatar
How can I Prolong The life of my Lt250r motor? I hate to have to get a top end rebuild when I could be out riding!Rite now my motor is in the shop for a $800 rebuild(top&bottom).
Thanks
1991 Lt250r :
Ceet seat cover,DG alloy front bumper,DG alloy rear grabar,DG alloy nerf bars ,Emgo bars,Pro design kill switch,Maier plastic(Looks awsome I put lots of cool stickers on it),Uni air filter,Shockwears,Parking brake block off,RTC clutch lever,Motion pro twist throttle(took a while to get used to!),Leager A arms ,Ohlins front shocks(got them with the quad the look kinda old),Homemade motor skid(from speed limit sign),Turf tammers on back,IPT hole shot up front,And probly other stuff to but I cant think of all of them rite now. Please go to www.screaminglt250r.homestead.com
Old Oct 3, 2000 | 10:24 PM
brokemybanshee's Avatar
the key is doing all the work yourself. I am relitevly new to atving and reparing machines but I have found that there is absoululey nothing to a 2 stroke motor, you CAN do it yourself. I never thought Id be able to tear those suckers down and rebuild them..... then I looked around... half of the atv repair shops around here are totall dumbasses.. crosseyed inbred hicks.. I said what the hell if they can do it I can do it. I have found that most do not have a clue. I talked to some guy that paid $850 to get a new topend in a blaster.. probally an hours worth of work and $125 in pieces.. Buy a book and do it yourself. A 2-stroke will break, get use to it. but if you have ever worked on a 4-stroke you will understand that it is peanuts workin on a 2up. First wheeler rebuilding was my banshee, Ive torn it TOTALLY apart 3 times now and each time it gets easier and easier.. When you get your wheeler fixed at a shop 90% of your money is goin towards labor 10% on parts. Do it yourself, you know its done right, and you save 90%. another good thing about rebuilding it yourself is when its all taken apart you can clean all the pieces and make it "showroom" mechanics and dealers do not scrape greese. :-)
Old Oct 3, 2000 | 11:01 PM
H300F's Avatar
i paid around $250 to have my banshee's top end rebuilt, bored 20over with wiseco pro lite pistons and cometic gaskets. i took him the motor witht the cylinders off and pistons off he gave it back all together ready to put in the frame. it was a small shop, but how could your friend pay 800 or whatever for 1 cylinder?? he got ripped off really bad.
I would say clean your air filter change the crank case oil and run the most oil to gas ratio you can,
Old Oct 5, 2000 | 12:54 PM
mindcrime's Avatar
I was ripped off by a local shop also. I had a CT Racing 310(actually a 295cc) Kit that sheared off the intake side of the sleeve's skirt. Took it to a local that was HIGHLY RECOMMENDED to be resleeved. After three months and $675, I put the complete motor into the chassis and rode it about one hour(after completing breakin). SHE SEIZED!!! Same carb settings as before--so I took the cylinder off. Guess what, the sleeve was 5mm OFF CENTER AND THE PORTS WERE NOT RADIUSED!!! He said that he sent it to LaSleeve to match the ports....NOT! After being out $$$$, I will do all my work myself too. My current motor(that I built) is running a Honda '89 cylinder and Pro-X pistons--if I lost ANY HP from the CT Kit, I sure can't tell it! As for engine life, a good synthetic premix and CLEAN INTAKE AIR, seem to go further in helping prolong engine life. I use Klotz R-50 mixed at 32/1 with a Dura Blue dual stage foam filter oiled with UNI foam filter oil. Love the smell of that KLOTZ!!
Old Oct 5, 2000 | 09:56 PM
lt250rman's Avatar
Thanks alot everyone! But also I would like to know how to properly break in an engine after a total rebuild.
thanks
1991 Lt250r :
Ceet seat cover,DG alloy front bumper,DG alloy rear grabar,DG alloy nerf bars ,Emgo bars,Pro design kill switch,Maier plastic(Looks awsome I put lots of cool stickers on it),Uni air filter,Shockwears,Parking brake block off,RTC clutch lever,Motion pro twist throttle(took a while to get used to!),Leager A arms ,Ohlins front shocks(got them with the quad the look kinda old),Homemade motor skid(from speed limit sign),Turf tammers on back,IPT hole shot up front,And probly other stuff to but I cant think of all of them rite now. Please go to http://www.screaminglt250r.homestead.com
Old Oct 5, 2000 | 11:31 PM
Dill's Avatar
heat cycles...
do 3-4 idle cycles allowing the motor to totally heat up..and let it cool down to dead cold in between. they ride it slowly and not revving it for 3-4 times, allowing it to fully cool in between. again, 3-4 times of somewhat revving it, then 3-4 times of short bursts of speed..
thats how I do it anyways, its all about heating up and cooling down the motor.
Old Oct 6, 2000 | 02:30 PM
mindcrime's Avatar
If you want a very detailed brake in procedure go to CT Racing's site or more precisely www.ctracing.com/pro-x.htm On page 2 there is a GREAT article with JETTING hints to keep your Two Stroke running TIPTOP. Building your motor shouldn't be imtimidating---just think of it as FUN EDUCATION!!
Old Oct 6, 2000 | 07:50 PM
lt250rman's Avatar
Thanks for all your help! please visit my site at
I made it a whole lot better! Dont forget to sign the guest book. thanks
Nondem
Feb 22, 2020 12:20 PM
kelleycully
Sep 15, 2016 02:57 AM
SDR-II
Sep 29, 2015 01:06 AM
Ask the Editor
12
Jul 21, 2015 06:57 AM
Shifts
Jul 3, 2015 07:59 AM
