Malossi parts
Old May 4, 2005 | 04:11 PM
tonnerre's Avatar
Default Malossi parts
someone know if Malossi build parts for the Predator 90 ? clutch, vario, reed, cylinder, crank..
Old May 4, 2005 | 05:49 PM
LT80's Avatar
LT80 Expert
I think yes.
Look into Koso parts also.
Old May 4, 2005 | 07:07 PM
TeamSRacing's Avatar
Jack, you are correct. Malossi parts will fit as well as the Koso ones.
Old May 5, 2005 | 03:20 PM
tonnerre's Avatar
do they build a cylinder kit ?
Old May 5, 2005 | 04:27 PM
Yes they do. Both brands in the 70 and I know Koso does in 90, 100, 105 and 110 as well.
Old May 5, 2005 | 04:30 PM
tonnerre's Avatar
I need a 90cc (92cc max)cylinder kit for my Pred. You speak about a 70cc not a 90, do they at Malossi ?
Old May 5, 2005 | 04:53 PM
Fastestdad's Avatar
i wouldnt use a mallossi cyl I'd try porting or a kit from WRH, Hetrick,miniatvs.com,but the mallossi kits and oring cyl heads are junk in my opinion.
Old May 5, 2005 | 05:01 PM
tonnerre's Avatar
May be you are true but it will be the more simply to find for me where I live
Old May 5, 2005 | 05:26 PM
I have to agree with Fasteastdad, I'm not much on the malossi stuff. If I were you I'd check out WRH, Hetrick or Maximum RPM. Any one of the three will get you what you need with a tech support package to boot.
Old May 5, 2005 | 08:26 PM
LT80's Avatar
LT80 Expert
Someone mentioned the stock heads.
I modded a stock one. The chamber design is ancient, but the only way to make it cuz of the stock design. That's why some say they don't work or call them bad.
I tried it on this Eton motor I just built. I figured why not. For some reason it's working just fine.
I do want to get the proper aftermarket head and make The squish band and clearance the way I do for my other race motors. Don't hurt to expierement ya know. [img]i/expressions/face-icon-small-smile.gif[/img]
