SCRAMBLER CLUTCH
Old May 13, 2005 | 01:58 PM
SCRAMIN's Avatar
Default SCRAMBLER CLUTCH
WHAT WEIGHTS DO YOU USE ON YOUR PRIMARY? THIS IS WHAT I HAVE 50 WEIGHTS HPD RED/ YELLOW LOOKING FOR MORE BOTTOM END POWER ? WHAT ABOUT HPD SILVER/GOLD SPRING OR SILVER SPRING?
I HAVE HPD TRAIL MOD WITH RACE MOD PIPE AND 39 PWK AND V-FORCE REEDS THANKS
Old May 13, 2005 | 03:37 PM
scramblerXrated's Avatar
ive got the HPD violet with 10-56 weights. tons of bottom end. but then again, the 400 and 500 are totally different for clutch setup.
X
Old May 13, 2005 | 03:53 PM
braveops's Avatar
right now i am trying the red/yel with s55 and it engages at 3500+ rpm and topping out @6700 rpm and rcr mid pipe and it seems to have good bottom end spins my 25" vampires easy
Old May 13, 2005 | 06:36 PM
ftwflh's Avatar
TRy a set of S58 weights and that should get you some bottom end but check to be dure you are getting full shiftout.If not you may have to go with a HPD red or violet.
Old May 13, 2005 | 06:54 PM
duneaholic's Avatar
X
Wow Charly. I didn't know that you ran that setup. I bet that sucker takes off like a rocket with as much torque as those machines have. That's what I run on my machine.
Old May 13, 2005 | 09:26 PM
[img]i/expressions/face-icon-small-smile.gif[/img]im usually all grins when im ridin!!!
X
Old May 14, 2005 | 12:13 AM
braveops's Avatar
what sort of rpm do you pull out of that?with that setup HPD violet with 10-56 weights
Old May 14, 2005 | 01:08 AM
well i am sorry to say that i dont have a tach hooked up yet.
but i have tried several springs and weights and this is by far the best out of the hole, seat of the pants, go get em feel that i have come across.
X
Old May 14, 2005 | 10:15 AM
scramblered's Avatar
race mod pipe? try the gold HPD primary or silver or for more
aggressive go for the blue with 55 g of weights.
with the trail mod the pipe won't peak as high it should be,i think
your setup should run around 69-7000 rpm.
fordfaithful21
Dec 7, 2015 05:52 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
1000gade
Sep 9, 2015 03:35 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
cdstang
Aug 31, 2015 07:52 AM
