just put it on alky --need help from some experienced alky users
Old May 17, 2005 | 10:01 PM
bigbird650's Avatar
Default just put it on alky --need help from some experienced alky users
well let me start with its all stock motor wise just got a pipe and ported intake and the tm45 -----well it seems strong on bottom and seems to run like the main is way to big -----it cuts out like you are hitting the rev limiter,then when you let off it pops a few times
the woods alky kit
main-300
95 needle-clip in the middle
pilot-65
not running the accelerator pump
Old May 17, 2005 | 10:24 PM
ANNIHILATER's Avatar
No Mercy Racing! Got NOS?
I think your pilot is too rich, What is your needle tube drilled to?
I hope this can help, I also think your running the bowl dry that might be why its cutting out on top. On my other 720 alsy ds I ran a 1/8 drilled needle tube with a 57 pilot and 250 main. You can use a decimal conversion chart and drill your own jets. I usually jet till I get a motor temp of 160-175ish. The alky will run best when its warmer out. 75 degrees and above. JMO Check your oil it may be milked. I was running the ac pump with the tm 48mm.
Old May 17, 2005 | 11:23 PM
bigbird650's Avatar
i bought the woods alky kit it cam with the y-8 tube(.125 inch) ,95 needle,mains 285-330,pilots 55-65, bigger needle and seat, drilled petcock so both reserve side and on side flow fuel
Old May 17, 2005 | 11:48 PM
Well, In the past I have leaned my needle out all the way to see if the bike pulls longer, then youll know if the bowl is going dry. BUT it would be better to change the main to around a 285 then see if its running hot.. If it starts to run hot richen it back up and try to get more fuel from the tank to the carb. Are you running a pingle or drilled out stock fuel switch. Big Fuel hose?
Oh and Im no expert with alky, But I made my old 720 run decent on it. When you get it dialed in make sure you write down the outside temperature, humidity and jetting so you know what works for the next time.
Old May 18, 2005 | 12:26 AM
bigbird650's Avatar
stock petcock --- 3/8 inch hose
Old May 18, 2005 | 07:06 PM
bigbird650's Avatar
do you think maybe i should go down on the main to 285? lean out the needle? go down on the pilot? sure need some help thanks guys
bmxatv10
Oct 14, 2022 06:23 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
exmotocrosser
Sep 13, 2019 06:12 AM
tysonbully
Sep 28, 2015 02:30 AM
Jeff Roper
Sep 21, 2015 02:11 PM
