400ex... help
Old May 23, 2005 | 07:37 PM
jordanregier's Avatar
Default 400ex... help
i have a 01 400ex and the spark in the spark plug isnt jumping the gap it jumps to the side of the plug...i have bought 2 new plugs n after about a week they stop working and jump to the side anybody have an idea on why it is doing this??
Old May 23, 2005 | 10:52 PM
emac's Avatar
what does the plug look like, any wear, discoloration things like that?
have u changed anything that would affect the engine[jetting, altitude,exhuast or intake mods]
Are you gapping your plugs correctly, get a gaping tool and see if your gap is set to the rite size?
are you sure that you are getting the rite plug. the only plugs i keep in my 400 are NGK plugs im not sure of the code on it tho
hope this helps, if you ave any other questions you can PM me, i have a real softspot for broken ex's.
Old May 23, 2005 | 11:09 PM
well i had the baffel cut out and ran it without the airbox lid for awhile then i relized it probably wasent to good for the motor so i have the baffel exaust tip on and airbox lid back on so that cant be the problam and other then that i dunt have anything done to it...it was wet when i took it out probably because i was trying to start it for awhile before i checked the plug and found out it wasent sparking right...and i am running the normal ngk plug that is told in the manual and do you have to check the gap or is it gapped correctly when u buy it...?
Old May 24, 2005 | 11:10 AM
warmdye's Avatar
The gap, you must check.
racerboy1234
Sep 22, 2013 06:47 PM
quadtrx400ex
May 24, 2012 04:32 PM
TacticalRedneckofKentucky
May 21, 2012 09:27 PM
Khoranic
Feb 2, 2012 07:37 PM
