Reverse Actuator on Xpedition
Old May 25, 2005 | 06:19 PM
oldlogger's Avatar
Default Reverse Actuator on Xpedition
Just wondering how many Xpedition owners out there are having the same problem as I am? The Reverse Actuator only works once in awhile when you push the Reverse Limiter button and try to shift into reverse. I have cleaned the connections many times and it will work fine for a short time. Can just reach back under the plastic cover and manually engage the actuator, but that gets to be a pain in the butt. I know three people locally that have Xpeditions and they are all having the same problem. I understand to replace the Actuator is a big and expensive job and I am not sure whether it is the Actuator itself that is the problem. Any ideas?
Old May 25, 2005 | 11:20 PM
425Xpedition's Avatar
The actuator is easy to replace and costs around $100 bucks.
Old May 25, 2005 | 11:37 PM
rmkcac700's Avatar
hey oldlogger, u can cut the cover off the actuator, clean it all up and put in new grease and clean all the contacts from the inside. they get spread apart from the harness swaying and dangling from the plug. once u have cut the cover off, use locktite 414 to glue it back on, and put a couple zip ties around it just to make sure it doesnt pop off. Ive done this to lots of units. Works great, and is cheap too....
Old Dec 18, 2017 | 09:52 PM
ddoubles817's Avatar
2000 polaris expedition
Do you know where i can get an actuator for $100?
Old Dec 19, 2017 | 07:44 AM
These posts were from 2005... Possible to get one for 100 bucks 12 years ago,but around 200 bucks now. This is the old part # that Partzilla still shows to have.I'd call first as the part # has changed and all the other sites I've see show nla.https://www.partzilla.com/product/po...444f34edb703a5
Old Feb 5, 2019 | 09:32 AM
Michael Clark's Avatar
Default Expedition reverse acutuator
I just replaced motor for the inside of acutuator for 5 bucks threw Walmart and couple modifications and works perfect.
Old May 30, 2019 | 07:27 AM
Dubya1111's Avatar
Default xpedition 325 reverse actuator
New to the forum. Just acquired a good condition xpedition 325 but it's missing the reverse actuator. I've tried to find even a used one online but haven't had any luck yet. Is there any other fixes (manual or redneck) to the missing actuator? Any help is appreciated. Thanks in advance.
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
r1pilot83
Sep 27, 2015 07:38 PM
poutlaw525
Sep 9, 2015 03:19 AM
