top end rebuild
Old May 31, 2005 | 01:52 PM
94sport400L's Avatar
Default top end rebuild
Recently got done rebuilding the top end of my 94 sport 400. (new wiseco piston and rings, .060 bore, .003 clearance)
I noticed that there is a constant ticking sound coming from the cylinder. Is this because the rings havent set or worn in yet?
What is the best way to break it in?
Any help would be appreciated...
Old May 31, 2005 | 01:56 PM
SPORTSMAN70003's Avatar
I resently put the topend in my friend 99 400 sport and never heard a ticking sound. I put a Wiseco piston .060 bored. He broke it in with a light trail ride.
Old May 31, 2005 | 04:12 PM
scramblered's Avatar
umm,no the rattle sound come from the .060 over piston wich
will knock a little stronger at idle but,that fine,they do sound as
the same after some boring,remember to spray after run- oil while
some rides then it should help reduce discharmonic orchestra.
Old May 31, 2005 | 05:35 PM
Thanks for the info guys...just wanted to make sure it was ok to run...
Old Jun 1, 2005 | 04:21 AM
jimmypsp700's Avatar
Mine makes a clicking noise stock and was told a Wiseco does even more so.
Jim
Old Jun 1, 2005 | 07:55 PM
Thanks.....any ideas on the best way to break it in?
Old Jun 2, 2005 | 03:54 AM
Vary the throttle , short runs cool down run again with no WOT runs.
Check jug bolts for torque.
Old Jun 3, 2005 | 01:53 PM
How long until being able to give it WOT? 1 or 2 tanks of gas?
Old Jun 3, 2005 | 02:04 PM
CED's Avatar
CED
1 tank is plenty,have fun.
Old Jun 4, 2005 | 01:29 PM
Bobjc90's Avatar
I recently read in a mag that you should ride at 1/4 throttle for 10 min increments, let it cool, and repeat at least 6 times, then change the oil, do it 6 times more, rechange the oil and then give it hell! Sounds like overkill to me but could be worth the trouble!
Beeline08
Nov 11, 2016 04:00 PM
scrounga
Honda Side by Sides
Mar 7, 2016 04:17 AM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
CosmoM
Sep 21, 2015 04:57 PM
