PWK 39mm problem. Choke does not fit.
Old Jun 7, 2005 | 05:48 PM
conig's Avatar
Default PWK 39mm problem. Choke does not fit.
So last night I decided to mount up my PWK carb 39mm on my scrambler 300, I will need to make some type of adapter so that I can get the carb to mount to the stock manifold but thats not a big deal.
I went to plug the choke into the new carb and it doesn;t fit the threads on the mikuni choke are about 1/4 inch to small. I don;t know why but I was under the impression that the choke would fit........Is there a particular choke I need?
I never used the choke with the mikuni carb and chance I could just plug the whole? I don;t mind an on the carb choke if anyone knows were to find one of those.
Old Jun 7, 2005 | 06:10 PM
CED's Avatar
CED
If you had a 34 mikuni on it,the 39 will fit.You need to start it at an angle then turn it as you go in,once you get it you will see what i am talkin about.You can get the plunger type choke **** at carbpartswarehouse.com., it will eliminate the cable.
Old Jun 7, 2005 | 10:49 PM
Whitedog's Avatar
An adaptor may also give you a velocity problem. And slow you down.
Just spit on it! It'll go rite in. [img]i/expressions/face-icon-small-happy.gif[/img]
Beeline08
Nov 11, 2016 04:00 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
wrencher82
Sep 24, 2015 03:39 PM
