help me with my trx200
Old Jun 9, 2005 | 09:07 PM
FromDaCity420's Avatar
Default help me with my trx200
i just got my honda trx200sx thats been in the garage for 2 years out and i took the old gas out, new spark plug... i try and start it up it doesn't want to start up, ill hold the start button for a few seconds and it will start like 1/10 times. the place where the air filter is i have little bits of gas kicking out of there. when i covered up the air filter hole with my hand it started up for like 5 seconds and died again. my battery is dead and i dont know what to do. (recoil start is an incredible waste of energy and time)
Old Jun 9, 2005 | 11:03 PM
TheTurtle's Avatar
if it starts with your hand over the intake (airfilter hole) A. your choke doesnt work or B. your possibly not getting enough gas. see if u can keep it runnin for 10 sec. NO MORE!!! by sprayin carb cleaner or starter fluid in the intake. i know someone will jump all over me tellin you to do this because it is possible fire could shoot back through the carb. ive done it a hundred times on cars atvs snowmobiles boats...pretty much if it has an engine ive done it. dont shoot a constant stream. start crankin it over and do short bursts. if it fires keep doin short bursts of what you are usin (carb cleaner or starting fluid) as the motor starts to die out. do not let the motor run for over 10 seconds if u have to keep sprayin to keep her runnin. it will burn up the piston or overheat if it is used for to long. I start my 250 2stroke snowmobiles like this atleast 10 times a year. it wont cause immediate enging damage.
Old Jun 10, 2005 | 01:39 AM
so after it runs for 10 seconds... let it sit for a while and try it again ... an hour later? couple minutes? you think ill have to do this every time i start up?? will it naturally fix itself. thx a lot though. i'm gonna try it tomarrow tell ya how it went.
Old Jun 11, 2005 | 12:50 AM
alright i got this beast running, but i was riding it today and i just ruined the sprocket, it like bent in hal :-/.... on another note my trx is getting MADDD hott really fast (like 10 minutes).... it was a little wet and i saw a lot of steam... any suggestions?
Jan 28, 2015 05:30 AM
jhrobert
Feb 17, 2008 09:31 PM
ripsaw0000
Dec 12, 2007 10:28 AM
mapsiam
Sep 4, 2006 03:51 AM
kingsnake
May 30, 2006 11:36 AM
