how do i replace my hub coil...
Old Jul 14, 2005 | 03:31 PM
locrian's Avatar
Default how do i replace my hub coil...
...on my 2000 scrammy 500 4x4? i can't figure it out ( well, haven't really tried), and i can't find it in the manual. i just don't want to mess it up. thanks,
bruce.
Old Jul 14, 2005 | 11:44 PM
locrian's Avatar
no one?
Old Jul 15, 2005 | 01:00 AM
ScramaDamaDingDong's Avatar
ok if you have the factory service manual it is on 7.13
Says remove the axle, remove the seal sleeve from strut housing using a drift punch and hammer (looks like you do this from the inboard side so since you have to disconnect the tierod to get the axle out anyway you can just turn the whole strut assembly sideways to get at the back.) tap the seal sleeve on each side so it comes out evenly. then it looks like the coil will just slide out and you'll have to dig out the silicon from the strut and then resilicon it when you put it back together.
Old Jul 15, 2005 | 09:44 AM
locrian's Avatar
ok. thanks eric.
toonces
Aug 5, 2015 05:55 PM
U2OFlyer
Aug 5, 2015 12:46 PM
toonces
Jul 28, 2015 01:58 PM
trouttracker
Jul 20, 2015 11:54 AM
jettman
Jul 6, 2015 12:16 PM
