metric zerks?
Old Aug 6, 2005 | 05:11 PM
wannabe1's Avatar
Default metric zerks?
Are the zerk grease fittings on the Kasea's a different type than our standard US automotive ones. I went to grease my new-used 90 and discovered that my standard grease gun won't fit on correctly. Can I change the fittings easily to standard or will I have trouble finding the right thread pitch? Or can I find another tip for the grease gun to fit the Kasea?
Old Aug 6, 2005 | 05:41 PM
ThrashAndCrash's Avatar
Unscrew the VERY tip of the grease gun fitting just a little bit (not off the hose....the end is actually 2 pieces)...........That adjust the jaws to fit tighter or more loose on the fitting..... I have never seen a different size grease fitting (the end that is.....[img]i/expressions/face-icon-small-happy.gif[/img])
Old Aug 7, 2005 | 01:08 AM
wannabe1's Avatar
Thanks for the tip, I learn something everyday. I have never had to make that adjustment before, but it worked, except on one fitting which I can't get any grease to go into. I removed the fitting and it is not clogged, but when I put the zerk back in I can't get any grease to go in. The hose/connection gets so pressureized that I can't remove the grease gun from the zerk w/o loosening the 2 end pieces that you previously mentioned.
Old Aug 7, 2005 | 01:34 AM
Take the zerk out and spray something like WD-40 in the hole and let it set for awhile, that may help.......what part are you talking about
? is it easy to take apart?
Old Aug 7, 2005 | 04:56 PM
wannabe1's Avatar
The part is the right rear A-arm mounting point.
bigred20653
Sep 19, 2015 02:11 PM
toonces
Jul 23, 2015 02:21 PM
AdamScramblr400
Feb 23, 2002 03:26 AM
Michimaniac
Aug 11, 2001 01:14 PM
cstark
Sep 11, 1999 01:21 AM
