What to grease on a Scrambler 400 2x4 ???
Old 02-22-2002, 11:45 PM
AdamScramblr400's Avatar
How often should I grease the two zerks at the bottom of the strut housings, the two a-arm zerks, the two swingarm pivot zerks, and the axle housing?
Is there such thing as over-greasing? I grease it probably one pump a week for all those zerks.
Should I be greasing any tie-rod ends, or steering stem stuff? I have a 2001 2x4, so I do not have the zerks on the steering stem.
Old 02-23-2002, 03:26 AM
modquad's Avatar
As long as you wipe off your excess grease...the old stuff pushed out, there really isn't any harm done. Try the Slick 50 One Grease ( even available at Walmart) it is teflon based. Teflon and water don't mix, so for the quads, you can't beat it. Same reason I use Tri-Flo on the chain.
Ken
exmotocrosser
09-13-2019 06:12 AM
Matt123
09-29-2015 01:29 AM
exmotocrosser
09-26-2015 08:18 AM
Nosparkpolaris
09-20-2015 04:21 PM
bigred20653
09-19-2015 02:11 PM
Quick Reply: What to grease on a Scrambler 400 2x4 ???
