Torn CV boots caused by gaurds
Old Aug 11, 2005 | 09:48 PM
84SHOVEL's Avatar
Default Torn CV boots caused by gaurds
Whats up people I recently bought a 05 700 carbed sportsman And I love almost everything. After riding through water at a preety decent speed the gaurds on the arms that are there to protect the boots folded back and cut the boots. The same thing happened to my buddies same bike. The dealer covered it but my warrenty is only so long and dont want to replacing these things every time I have a little fun in the water or mud. Any suggestions like after market gaurds and where to get them. Has anyone else had this problem? Thanks for any replys.
Old Aug 11, 2005 | 09:52 PM
Bretman's Avatar
they make different types of gaurds, yuo can get meatal ones, if i were you i would just weld a small piece of rod to the back of each of them so that when the plastic gaurd goes back, the little rod stops it.
Old Aug 11, 2005 | 10:12 PM
ChaddB's Avatar
Mine did the same damn thing on my 05 700 EFI. I fixed the boot and the next weekend it did it again.. I just trimmed the guard so it can't hit the boot.
Old Aug 12, 2005 | 07:19 PM
84SHOVEL's Avatar
I looked at the gaurds today and I noticed that on the side the dealer fixed under warrenty the gaurd looked farther from the boot than the still original side. They took the gaurd off and bent the taps that the gaurds mount to forward. So I did the same to the other side I dont know if this is gonna work but I,ll let you all know. Theres definitly more clearence between the gaurds and the boots now.
Old Aug 12, 2005 | 11:15 PM
Kushman's Avatar
Those05's must be way different that the 04's. Mine are rather tough,, If I hit something hard enough to bend mine back, I'd have bent an a-arm
Old Aug 12, 2005 | 11:16 PM
Kushman's Avatar
Whats the deal with the word tough turning into a Polaris link in this forum?????
Old Aug 13, 2005 | 12:16 AM
DANO38's Avatar
I noticed for some reason the front guards on my new '05 were a lot closer too than on my '03. I did the same thing, I removed the guards and bent the steel tabs forward. They've stayed put ever since. I also checked and found the part numbers have changed for the new '05 front control arms on the twins, so my guess is the arms are also new, and they just didn't have them jigged up correctly when they welded the tabs on. It's a simple fix, and I was lucky to catch it on mine before it rubbed through the boots!
Old Aug 13, 2005 | 04:26 AM
ScramaDamaDingDong's Avatar
I think this happened on my scrammy, I thought I toasted the cv joint since their was grease everywhere I'll have to check the boot closer and see if it's just torn. I was blasting through water pretty quick all day when it happened.
Jeff Roper
Feb 1, 2022 11:48 AM
wrencher82
Sep 28, 2015 10:02 PM
95scramblerruben1033
Sep 23, 2015 06:29 PM
jankerstien
Sep 21, 2015 03:09 AM
