2004 Sportsman 400 leaking coolant from wheap hole
Old Aug 12, 2005 | 01:06 PM
Murph22083's Avatar
Default 2004 Sportsman 400 leaking coolant from wheap hole
I noticed my coolant to be a little low the other day. I was inspecting it and noticed that coolant is dripping from the weap hole underneath the warerpump. Does anyone know what I need to replace in the water pump to stop the dripping. Thanks
Old Aug 12, 2005 | 01:23 PM
chevyboy400's Avatar
is it leaking from the water pump itself or is it leaking from where the waterpump connects to the engine? from the waterpump- buy a new one or try soldering/welding it. From the connection, most likely a gasket.
Old Aug 12, 2005 | 01:30 PM
Murph22083's Avatar
It is a small 1/8 inch hole below the pump on the block that coolant is leaking from.
Old Aug 12, 2005 | 01:35 PM
1/8 inch hole on ur block aint a small hole. you can weld it if you are a good welder, or take it to a local machine shop and have them do it would be the cheapest way, or you can buy the block which would cost a little err lots more.
Old Aug 12, 2005 | 01:47 PM
Murph22083's Avatar
No, the hole is supposed to be there. It has been that way since it was new.
Old Aug 12, 2005 | 01:54 PM
since when is a hole in your block natural? ill have to look at pics. maybe you bought a lemon.
Old Aug 12, 2005 | 02:01 PM
whats the part number on the water pump?
Old Aug 12, 2005 | 02:48 PM
Murph22083's Avatar
Pretty sure the hole is supposed to be there. It was definately machined there when built. The impeller is actually in the block, with just a small cover over the top.
Old Aug 12, 2005 | 03:11 PM
well, sounds like i cant help you if you wont give me some numbers. sorry
Old Aug 12, 2005 | 03:17 PM
Murph22083's Avatar
Dude I dont have the numbers, but I can send you here. It is a parts breakdown.
http://216.37.204.202/polaris_oem/Po...=13&A=330&B=46
