450 ES Reverse won't work
Old Aug 15, 2005 | 11:39 AM
GooseEgg's Avatar
Default 450 ES Reverse won't work
Reverse stopped working on my '02 - 450ES, I've heard its usually the cable out of adjustment ... is this an easy do it yourself fix or a dealer issue... can anyone point out where to start for me?
Thanks
Old Aug 15, 2005 | 12:47 PM
hondabuster's Avatar
The freeplay is adjusted up by the lever, its supposed to be 1/16 to 1/8". Then check down by the crankcase to see if the lever down there moves. Shoot some lubricant down the cable, as long as your adjusting it.
Old Aug 16, 2005 | 09:31 AM
GooseEgg's Avatar
OOOPS! The adjusment nut was very rusted and in the process of loosening things the whole thing snapped ... guess I'm looking at a new cable?
Where does the cable actually connect ... under the right foot? What kind of a job is replacing the cable?
Thanks
Old Aug 16, 2005 | 01:33 PM
The rust probably got inside the cable, and thats why it wasnt working. I think its pretty straight forward on the replacement. When you get the new one, route it the same way as the original.
Reactant
Mar 30, 2022 02:08 AM
hugemoth
Jul 20, 2020 03:28 AM
Scottma518
Jul 10, 2015 12:42 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
