blaster porting
Old Aug 24, 2005 | 08:06 PM
mawcus's Avatar
Default blaster porting
Hey I just got my blaster ported an man i am impressed.4th gear pulls so hard that it wants to flip backwards in 4th without even popping the clutch.The only thing is that I thinki might be running lean.I get it wide open in 4th and pull tha clutch.When i pull the plug it is almost white but when it cools it is a medium coffee color Whats the deal?help
Old Aug 24, 2005 | 08:42 PM
mawcus's Avatar
anyone?
Old Aug 24, 2005 | 08:50 PM
enFORCER's Avatar
Are you running the stock 26mm mikuni carb??? What pipe do you have on it??? Are you running a stock air box??? Have you advanced your timing any??? What is your elevation??? What jets are you running right now???
Old Aug 24, 2005 | 09:02 PM
mawcus's Avatar
stock carb pro circ platinum pipe k&n filter lid removed sstock everything else oh yeah i live in south louisiana 0 elevation super high humidity not sure what jets
Old Aug 24, 2005 | 09:19 PM
enFORCER's Avatar
Well if you have the stock jets in it, witch I believe are around 210 then it is way too leanl!!!
Go buy some jets at your local stealer 260-300.... I would at least start with the 260 and see how it runs....
franklyme
Oct 21, 2016 07:18 PM
QuadRiders
Oct 22, 2015 04:13 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
