Exhaust header pipe question. Heat tape or paint ???
Old Aug 26, 2005 | 03:35 AM
Mrneg9's Avatar
Default Exhaust header pipe question. Heat tape or paint ???
Hey guys. I was looking at the DS today and don't like the look of the light color rust orange the exhaust header pipe is. I was thinking of wrapping it in black header tape or painting it with high temp black paint. Header tape and ties are going to cost me around $50.00. Or I can go with Duplicolors high temp paint. $5.99
Resists temperatures up to 1200 degrees F, intermittently
Durable ceramic formulation
Tough cured finish resists oil, gas grease, rust, salt, humidity, and solvents
6 colors
EZ Touch®
I'm sure a couple of you guys have already been down this road. If I go with the paint is 1200 degrees F enough or will it burn off. Thanks, D
Old Aug 26, 2005 | 05:00 AM
ThrashAndCrash's Avatar
been there done this..........Use the header wrap!!!!!!!!! My wifes quad would fry your leg off from the head pipe....so I used header wrap to keep the heat off your leg a bit..........Ends up...it looks cool and clean, it keeps the heat off your leg, and it keeps the head cooler also (the pipe is 1"1/2 inches from the head) ......The only thing about the header wrap is...............Do not let it sit wet. Any time you get it wet...run the bike until it is dry, and store it in a dry place. The header wrap will hold water and it will rust your headpipe QUICK!
The paint ALWAYS discolors................
Old Aug 26, 2005 | 08:15 AM
sam's Avatar
sam
I think you might be able to use paint for wood stoves usually only black. I think they were rated at 2000 or 5000 deg. cant remember. they may hold up w/ that.
I do belive the pipes are SS. I would think one could take them off and clean them up to look good again.
what ever you use know how it goes.
Later,
Old Aug 26, 2005 | 09:57 AM
SCOUNDREL's Avatar
I use this and it works great!
PJ1 HIGH TEMP PAINT
2000F
Old Aug 26, 2005 | 10:14 AM
mudnuri's Avatar
Have you considered Jett Hott?
Old Aug 26, 2005 | 12:35 PM
DaBomb650's Avatar
I agree, get it ceramic coated. Look at the Big Gun, it is ceramic coated, mine looks GREAT!
Old Aug 26, 2005 | 01:06 PM
Mrneg9's Avatar
Where can I get that done and how much ?
Old Aug 26, 2005 | 01:47 PM
DaBomb650's Avatar
Find a place in your local phone book that does ceramic coatings for racing headers. Thay can do it. That would be my suggestion.
mudnuri's Avatar
http://www.jet-hot.com/
Don't settle for anything less.
Old Aug 26, 2005 | 08:13 PM
bassetboy55's Avatar
i just looked at jett hots site. They seem to have a pretty good product.
Bonzhonda300ex
Sep 17, 2015 10:44 AM
awer1968
Sep 8, 2015 11:02 AM
Slagpolaris
Sep 5, 2015 09:41 PM
Brandon400
Sep 5, 2015 08:44 PM
antiguogrumete
Sep 5, 2015 03:41 AM
