WHAT OIL DO YOU USE IN YOUR PREDATOR???
Old Aug 31, 2005 | 12:49 PM
Fixitmatt's Avatar
Default WHAT OIL DO YOU USE IN YOUR PREDATOR???
I've been using the polaris ps-4 oil since it was new,and i have to admit it really kept my engine clean. when i had the whole engine apart it was very hard to beleive how new every part looked,and i beat the snot out of it.The one thing i cant take/stand about the oil is it expands alot!! it is a pain in the *** to fill right and the more oil your tank holds it seems to expand more. I just can't get it right ,the oil is always spitting out of the vent tube. I only fill my CMF oil tank to the half way mark at new oil changes because anymore would be a mess.But even just filling half way causes a mess when it really gets hot.I"M TIERED OF THIS.
What is the best oil to use in my predator----it's modded big time---what are you all using?
Old Aug 31, 2005 | 02:29 PM
XShowtimeX's Avatar
I use the Polaris PS-4.
Old Sep 1, 2005 | 05:28 PM
Fixitmatt's Avatar
come on people what are you using.even if it's ps-4 i want to know.
Old Sep 1, 2005 | 05:33 PM
bassetboy55's Avatar
yamalube, but i ride a raptor.
Old Sep 1, 2005 | 06:07 PM
cornbread2's Avatar
Any good synthetic motor oil will work fine.
Old Sep 1, 2005 | 06:56 PM
Predator03's Avatar
I always use the PS-4 in mine....One time, I did not, however....and it made the shifting notchy. I went back to PS-4 after that, and have had no more problems.
Old Sep 1, 2005 | 07:23 PM
Hoopie's Avatar
I use Ps 4 but may switch to Amsoil synthetic 0w40. Not because Im disatisfied but because of cost. Amsoil is cheaper and is a good oil. Not any synthetic will work. Must be oil for a wetclutch at 0w40.
Old Sep 1, 2005 | 08:25 PM
speeeedy's Avatar
i use amsoil 10-40 in the winter and 20-50 in the summer. i live in vegas so it does not get to cold. matt smiley uses klots 10-40. these motors run hot so i dont use the 0-40.
Old Sep 1, 2005 | 10:00 PM
cornbread2's Avatar
I forgot about the wet clutch. A really good synthetic can make the clutch slip after a while.
I use Castrol 20-50 in engines with a wet clutch.
Old Sep 2, 2005 | 12:30 AM
tmorris1's Avatar
The Amsoil 0W40 and 10W40 are both rated JASO MA for wet clutch use. so you should be fine with either one. I ise them in my dirt bikes with good results. Another good oil in Mobil 1 MX4T 10W40 motorcycle oil.
