WHAT OIL DO YOU USE IN YOUR PREDATOR???
Old Sep 5, 2005 | 01:10 PM
  #31
RAJ's Avatar
RAJ
Default WHAT OIL DO YOU USE IN YOUR PREDATOR???
I only put in 2 qts of oil, the 05 manual is wrong. It said 2 1/2 qts, and if you do this it will come out of the crank case vent. I would only use 2 qts and was fine.
Old Sep 5, 2005 | 01:16 PM
  #32
Hoopie's Avatar
The Manual isnt wrong its just that when you change your oil, not all the oil comes out of the engine.
Old Sep 5, 2005 | 01:42 PM
  #33
Fixitmatt's Avatar
I have the cfm oil tank , supose to be 3 quarts . any for now it seems fine i put 2 1/2 quarts in and so far so good. could the oil tank be the problem too. Isn't the oil tanks supose to have baffles in them to stop oil from being pushed up the hose. i don't think the cfm oil tank has this.
Old Sep 10, 2005 | 04:58 AM
  #34
mcloud9's Avatar
I use MOTOREX PLUS OIL for better result,my Tld need cold blood.
Old Sep 19, 2005 | 06:02 PM
  #35
love2tinker's Avatar
I use Mobil-1 suprisingly enough...I am suprised that no one else uses it. Shifts better than it did when it was new. Plain old Synthetic 0W-40....works great.
Wes
Old Sep 19, 2005 | 06:17 PM
  #36
RacinJason's Avatar
The oil itself isn't expanding
The level will come up after the quad is at operating temp
The oil resv will not hold the entire amount of oil needed...add what you can then spin the motor over with the switch off
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
Elkaholic
Sep 6, 2015 02:44 PM
Hankey Pankey
Jul 31, 2015 05:50 PM
1966F100
Jul 14, 2015 12:19 PM
1966F100
Jul 12, 2015 03:08 AM
