Dial-A-Jet?
Old Sep 1, 2005 | 08:57 PM
2FAST4U69's Avatar
Default Dial-A-Jet?
Anybody ever try the dial a jet system on their bike? How did it work?
Old Sep 1, 2005 | 10:09 PM
Trxoutlawz's Avatar
Default Dial-A-Jet?
I use the dial a jet on my 440ex.. Mine is tuned and setup for about 3500 up to aprox. 11000'. It is as simple as a small screwdriver and twisting the adjuster, 5 different settings. It took me a couple of trips to find the correct main for the range I wanted.
I like it very well.
I am using a 39mm fcr with my 440 kit..
Old Sep 1, 2005 | 11:02 PM
wolverine68's Avatar
Default Dial-A-Jet?
I put one on the wolverine about a month ago. I ride from about 2000-9000ft and temps. between -30and 90F. So far I have used it in the aformentioned elevation range and it works as advertised.[img]i/expressions/face-icon-small-happy.gif[/img]
Old Sep 1, 2005 | 11:55 PM
2FAST4U69's Avatar
Default Dial-A-Jet?
Thanks for the info. After re-jetting my raptor a few times it got old really fast, so I think i'll just buy one of these set up's...
Old Sep 1, 2005 | 11:58 PM
Air's Avatar
Air
Default Dial-A-Jet?
Had a buddy who did the same thing on his rappy.
Old Sep 2, 2005 | 12:00 AM
2FAST4U69's Avatar
Default Dial-A-Jet?
How did it work after he did it?
Old Sep 2, 2005 | 12:01 AM
Air's Avatar
Air
Default Dial-A-Jet?
He was able to ride from 4500 to 12000 ft with jus a couple of clicks. It beats jetting a 660r
Trxoutlawz's Avatar
Default Dial-A-Jet?
Take your time and think about your install before you make any cuts or holes... The system works very well.. You will be pleased once you get it all dialed in...
Old Sep 2, 2005 | 12:06 AM
2FAST4U69's Avatar
Default Dial-A-Jet?
Thanks for the replies. Sounds like a quality part... What are and how hard are the procedures to install?
Old Sep 2, 2005 | 01:05 AM
Trxoutlawz's Avatar
Default Dial-A-Jet?
You will actually get detailed instructions and they are very easy to follow.. You will need to drill a small hole in your air boot with the tool provided. Just make sure of the possition for the actual dial box and any other obstructions where you will band it on..
It is not that hard..
STLyamwar
Jul 25, 2020 04:44 AM
jnisson
Jun 14, 2004 07:21 PM
joequad
May 15, 2004 01:39 PM
Vforcer
Aug 8, 2003 01:41 AM
Oxygen
Feb 24, 2003 09:14 PM
