milky tranny oil
Old Sep 3, 2005 | 04:36 AM
EdgeRacing's Avatar
Default milky tranny oil
i changed the oil in my tranny not too long ago and i just checked it a couple days ago and its like a light milky brown.... and usually that means theres water in it right? but i havent had the thing in any water since i changed the fluid. so whats goin on with this? thanks guys...
Old Sep 3, 2005 | 09:19 AM
Jayblazer's Avatar
it may take a couple of oil changes to get the water out i have heard of something you can spray in there
between the oil changes to dry it out but i cant remember what its called. this is your tranny right and not your counter balance. if its your cb thats something totally different.
Old Sep 3, 2005 | 09:30 PM
EdgeRacing's Avatar
no... its the tranny. i changed the counter balance too and that wasnt too bad
Old Sep 4, 2005 | 11:06 AM
scramblered's Avatar
what oil do you use?
when you got the old oil dumped out,take some good spray oil
to fill in the tranny hole,and spray it whenever possible,it will
help to clean the tranny case out and is just good for the chain then.
Old Sep 5, 2005 | 09:27 PM
tmzg29's Avatar
Drain your tranny fluid and spray in some PB Blaster. It will get rid off all moister in your tranny. Then drain out all the PB Blaster. ( I would use the hole can) Then put your new tranny fluid back in. You should change you fluid after you first ride just to make sure all water and PB Blaster is gone. I swear by the PB Blaster. I got water in my counter balance oil. I changed the oil about 10 times and still had water. I used 1 can of PB Blaster and all the water was gone.
Old Sep 5, 2005 | 11:51 PM
cornbread2's Avatar
You had best check that counter balancer everytime you ride.
That old 400 two stoke is a good engine and it is cheap to rebuild as long as the counter balancer does not come apart.
Once it comes unglued it is all over but the crying.
They seldom fail as long as they have good clean oil in them.
Njrider1230
Jul 29, 2023 05:16 AM
Logan Collins
Sep 5, 2015 08:03 PM
Haakon
Aug 24, 2015 01:54 PM
DOAinNY
Jun 12, 2015 02:26 PM
drlaney
Nov 21, 1999 02:33 PM
