400 sportsman no power
Old Sep 4, 2005 | 10:09 PM
butch1234's Avatar
Default 400 sportsman no power
i have a 2004 400 sportsman there is gas leaking out of a hose attached to the bottom of the carb i moved the hose so it pointed up and the gas stopped but now i noticed the bike has no power on hills and bogs out only 10 mph up hill . any ideas
Old Sep 4, 2005 | 10:23 PM
SPORTSMAN70003's Avatar
Sounds like your float level is to high in the carburator.
Old Sep 4, 2005 | 10:48 PM
stormyseas's Avatar
I had the very same problem this past summer, took it to the dealer and he replaced the jet. All he told me is that I had a bad jet. Still under warr. so no big deal.
Old Sep 5, 2005 | 02:33 AM
Polaris500HO4x4's Avatar
that is your overflow hose and it should have tiny ammounts of gas dripping out of it shouldnt be running out, point it back down and your power should come back
Old Sep 7, 2005 | 12:14 AM
WVRed's Avatar
I dont have a Polaris but I can tell ya when I had gas coming out the same hose on my carb the float needed cleaned. If it has sat a lot especially it will cause this. Clean your float bowl and you should be good to go.
Old Sep 7, 2005 | 11:19 AM
ScramaDamaDingDong's Avatar
if your fuel is pouring out don't do this before you adjust your float.
And I don't understand how a jet could cause this problem.
Old Sep 7, 2005 | 11:51 PM
Butch explain this a little better, is gas running out or dripping out or dribbling out????
Jmuddin284
Jan 19, 2026 07:16 AM
Cole Hadden
Jun 15, 2025 09:05 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
tweeder
Jul 5, 2015 01:57 PM
