Chain question
Old Sep 13, 2005 | 06:09 PM
new2atv's Avatar
Default Chain question
I have an '01 Xplorer 400 4x4. Is there a way to tell if my chain is getting stretched out and needs to be replaced (besides being loose)? I need to tighten it but I want to make sure it's not getting stretched out.
Thanks.
Old Sep 13, 2005 | 07:28 PM
cornbread2's Avatar
It will be time for a new chain when you run out of adjustment.
Old Sep 13, 2005 | 11:13 PM
ftwflh's Avatar
Clean the chain and look for broken or missing rollers along with the stretching.
Old Sep 14, 2005 | 10:08 AM
new2atv's Avatar
Thanks guys. When I go to tighten it I'll check it over really well.
Old Sep 14, 2005 | 10:19 AM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
You can tell how much your chain has worn by pulling on the chain on the back of the rear sprocket. When it can be pulled off of the teeth it is shot. The more of the teeth that are exposed the worse the wear is. Try it with a new one it wont pull up at all.
Firefighter400
Oct 8, 2022 06:38 PM
frostphase
Aug 23, 2015 07:36 PM
Anomers
Aug 16, 2015 11:06 AM
DeFox500
Aug 14, 2015 05:59 PM
95wolv
Jul 17, 2015 08:13 PM
