250x problem
Old Sep 14, 2005 | 09:20 PM
MdotHolla's Avatar
Default 250x problem
Ok guys I need some help. I just replaced my chain because my other one broke and its on. When the chain broke it all got clogged up in the front drive sprocket. Now when I start to pull off in 1st gear the chain is pulled to the right(maybe because it is too tight?) and I think it rubs on the swingarm and it grinds down the rubber guider/slider(the long one on the top). Now I think its the front drive sprocket because I can pull and push it, it has some play. Not too much but enough to cause this problem.
Can anyone tell me whats wrong and how to fix it. DO I need to ben the slider back to position because the chain doesnt even sit in the center of it. It sits a little to the right of the center. Do I need to tighten up something? If so, how and what. Thanks in advance.
Mike
Old Oct 9, 2005 | 11:47 AM
4trax67's Avatar
I have exact same machine bought it new in 87. What your discribeing is identical to mine. The front sprocket is suppose to move some and as far as the chain rubbing on the glider thats normal are you sure your skid plate is not bent up to close to the chain as it comes off front sprocket slack should be 1 3/8 to 1 3/4 of a inch. A loose chain is better then a tight one. To tight you wear parts quick. Would you be interested in selling your machine?
Old May 10, 2006 | 03:14 PM
gotanswers's Avatar
youve twested your chain most likely or check back sprocket to make sure not bent that will also trow chain
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
