Predator will not start
Old Sep 27, 2005 | 09:37 PM
IE's Avatar
IE
Default Predator will not start
my 03 predator will only start if i push it then pop it but when i use the electrical start it just turns and does not fire any sugestions ? ?
Old Sep 27, 2005 | 10:17 PM
Jayblazer's Avatar
never mind your quad does not have one maybe one of these gears are stripped click me
Old Sep 27, 2005 | 10:32 PM
IE's Avatar
IE
What is that
Old Sep 27, 2005 | 10:37 PM
Bradracer18's Avatar
Make sure you have spark at the plug first..........if so.....then make sure it is getting fuel.........if so........then probably a starter or fuse problem........
Old Sep 27, 2005 | 10:40 PM
IE's Avatar
IE
if i can push start it does that mean i have spark?
Old Sep 27, 2005 | 11:37 PM
Cutfoot's Avatar
What happens when you pull the choke out? Do you have a aftermarket breather hose on your gas cap? Had similar problem with friends 04' pred the other day, would only start if choke was all the way out. Filled up gas tank and it finally stayed running.
Old Sep 27, 2005 | 11:45 PM
cr125predator's Avatar
No if you push start it doesnt mean you have a spark. what you will want to do is pull out your spark plug but leave the cap connected. Make sure the spark plug is grounded (i.e have it touching the cylinder or something like that) then push the start button and if there is a spark you will see it. if not then like bradracer18 said, you will want to look at your gas line and then check
Old Sep 28, 2005 | 03:34 PM
heatseeker8's Avatar
WELCOME TO MY WORLD!!!
Have the same problem and it now has a bad intake valve...the quad has less than 50 hrs on it.
start by adjusting your ETC and go from there.
Make sure to visit www.predatorowners.com
Keep us updated!
Old Sep 28, 2005 | 05:08 PM
Fixitmatt's Avatar
been there done that! IT'S YOUR VALVES! either out of adjustment or stuck open or springs Anyway you look at it I bet your valve need work.
cbcole02
Sep 7, 2015 06:16 AM
Berjr
Jun 15, 2015 04:41 PM
Predator_500
Jun 13, 2015 03:01 PM
1000gade
May 27, 2015 12:37 PM
Falcon150
May 25, 2015 05:36 AM
