car problem
Old Oct 1, 2005 | 04:33 PM
Anton's Avatar
Default car problem
Ok here we go again.
03 400 auto, was out for a run and when I let off gas idle, came down it would stall when I gave it gas. Maybe dirt in carb, so I cleaned it top to bottom with carb cleaner.
now took it out and will not go over 20 miles hr.
Move air mixing screw to factory setting
Took the throttle cable off found it was loose so I tighten it.
So what is going on here
Thanks [img]i/expressions/face-icon-small-confused.gif[/img]
Old Oct 1, 2005 | 06:27 PM
Bear4570's Avatar
Default car problem
Clean the air filter. Drain float bowl on the carb. If all else fails pull the carb, tear down, clean and reassemble and reinstall.
Old Oct 2, 2005 | 10:31 PM
Anton's Avatar
Default car problem
Bear
Just thinking about it, what if I put the float back in upside down would this cause the engine to run like this. was driving today and had time to think about it
[img]i/expressions/face-icon-small-blush.gif[/img]
Old Oct 2, 2005 | 10:41 PM
Bear4570's Avatar
Default car problem
Originally posted by: Anton
Bear
I have never seen it done, but it is possible that's for sure. If you are in doubt, you had better check.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
