2001 honda recon please help
Old Oct 20, 2005 | 06:29 PM
homerjay's Avatar
Default 2001 honda recon
i have a 01 honda recon and just yesterday i was loading it in the back of a ford ranger and it stalled. it now stalls any time i try to load, unload, or go up any type of hill. i do alot of work myself and was wondering if anyone had any ideas on what the problem was. i want to ride saturday so any help would be greatly appreciated.
Old Oct 20, 2005 | 09:52 PM
ckok's Avatar
Default 2001 honda recon please help
I have an '02 Recon that stalls when I unload it from my F150 sometimes. I just use it around the farm so I really don't know if it would stall on a sustained climb. It has never stalled while loading though. I will be interested to see what is causing your problem.
Old Oct 21, 2005 | 02:27 AM
exrider4130's Avatar
it sounds like a fuel problem. does fuel run from the overflow tube? try to get it on a hill and see if giving it gas helps to keep it from stalling.
Old Oct 21, 2005 | 12:23 PM
homerjay's Avatar
i have taken the carb off and cleaned it, yes the fuel does come out the overflow. giving it gas does not help. you have to choke it to get it started when you get back to flat land. any other ideas?
Old Oct 21, 2005 | 03:05 PM
homerjay's Avatar
i have taken the gas tank out cleaned it carb off several times and still no luck anyone with any ideas ? i even took off work today to fix it for riding tomorrow.
Old Oct 21, 2005 | 03:16 PM
its got to be a carb problem, theres no other reason for it to do this. if you have any experience with carbs, pull the carb off and check the jets and needle. make sure theres no dirt or grime in the carb bowl. also, check to see if ther fuel screw or idle screw havent been hit or moved fro there preset position. the owners manual will tell you where they should be. if none of this works, it may need a carb rebuild.
Old Oct 21, 2005 | 03:17 PM
ill call some buddies to see if they have an idea. it sucks not being able to ride. i know how you feel.
Old Oct 21, 2005 | 03:54 PM
homerjay's Avatar
i have done the carbthing a few times. i thought it was the float getting stuck. i looked at every thing i could think of cleaned it checked the float and still the same. its driving me crazy, i just went and got new gas and still the same
the pic above my name is exactly how i feel
Old Oct 21, 2005 | 05:23 PM
homerjay's Avatar
i got it! one of the vent tubes was clogged, never looked in there. thanks for the help!!!
Old Oct 21, 2005 | 08:10 PM
cool man, have fun riding
peytonius
Sep 28, 2015 02:18 PM
Hondamx751
Aug 13, 2015 01:06 AM
MNatv89
Aug 12, 2015 06:00 PM
MNatv89
Aug 10, 2015 02:20 PM
MNatv89
Jul 7, 2015 11:36 AM
