stalling????? how dare u!
Old Oct 21, 2005 | 06:40 PM
roncorox's Avatar
Default stalling????? how dare u!
i cleaned out my carb which was causing me not to start my quad. but now wen i take the choke off my quad runs and then sputters then stalls. could anyone give me an idea. would be most appreciated its a honda trx90
Old Oct 21, 2005 | 08:20 PM
exrider4130's Avatar
did you completely take the carb apart, or just spray carb cleaner in to it???
if you took it apart, go back and recheck that you've reassembled it correctly and that you've reconnected all hoses and vent tubes. double check that the choke is working properly. when i bought my brand new 300ex, it wouldnt run at the dealership. the choke had been installed wrong and it was working backward somehow.
if you just sprayed carb cleaner into it, you may have alot of it built up in the carb, try and let the quad idle for a while and let it clean itself out
Old Oct 22, 2005 | 12:53 AM
roncorox's Avatar
o yeah i did take it completly apart because it had gelled up gas in there so i had to get that out and the floater was fine. The engine is getting gas because you can smell it from the exhaust, not like the pure form of gas but just a remnence of it. But do you think maybe some of the gelled gas is in my cylinder? I know my choke isn't on wrong because I've had the quad for about 5 years. But how would you tell if it is a bad choke?
Old Oct 22, 2005 | 01:57 AM
Doctorturbo's Avatar
GOT BOOST!
Your pilot jet is clogged up from the gel. Had the same problem on a 1100 once. No amount of carb cleaner would clean it out. Clean the pilot out and it will run fine.
Old Oct 22, 2005 | 02:25 AM
roncorox's Avatar
alright thanks alot guys ill try it tommorrow
Pehter
Oct 3, 2024 11:00 PM
QuadRiders
Oct 22, 2015 04:13 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
nastyblaster100
Sep 13, 2015 01:19 PM
