440ex
Old Nov 8, 2005 | 08:42 PM
Gunter06's Avatar
Default 440ex
I just bored my 400ex to a 440. i put a stage 2 hotcam in also. i was just wondering if they 440's are known to leak oil from the head. i was thinking maybe just the head gasket is blown. thanks
Old Nov 8, 2005 | 09:43 PM
TractorPacker's Avatar
Do you have a balloon?
Default 440ex
Take it back apart, something is wrong. Hopefully its an easy fix.
Old Nov 8, 2005 | 10:09 PM
Gunter06's Avatar
Default 440ex
well it was bored bout 3 weeks ago, and just started leaking. so i took off my valve cover and tighten the head nuts more. they were a little loose. i was just wondering what problems that a 440 is know for.
Old Nov 8, 2005 | 10:27 PM
Default 440ex
OOh thats scary. Some 440's have pulled the studs out of the lower cases. That is normally at 12:1 compresion and higher.
Old Nov 8, 2005 | 10:38 PM
Gunter06's Avatar
Default 440ex
ya i think mine is 11:1 but it may be 12:1. ive heard that to. i dunno well see how it goes
Old Nov 9, 2005 | 12:57 AM
dunefool's Avatar
Default 440ex
You will probably have to get heavy duty studs put in. All 440's that I have seen leak at least a little.
Old Nov 9, 2005 | 09:37 AM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Default 440ex
When I installed my 440 kit I had a oil leak from the head as well. I took it back apart and torqued the head bolt to spec with a new gasket and didn't have a problem afterwards.
Old Nov 10, 2005 | 05:15 PM
Gunter06's Avatar
Default 440ex
cool that what i did so i hope i have some good luck. thanks everyone
Old Dec 6, 2005 | 05:38 PM
440EX026's Avatar
Default 440ex
Its really more of a compression issue than the larger bore, but any additional energy created inside the cylinder will put additional stress on the head studs/bolts.
I actually had been running a true 12.6:1 for over two years with no noticable problems until recently.
Now I am debating between helicoils, larger studs, switching to larger bolts or ?
The problem seems to be completely from the stud pulling up thru the threads in the cylinder and tearing the threads up while it does it.
Curious if anyone is knowing what dia replacements are used in the HD stud kits?
Blodg500RX
May 6, 2001 06:42 PM
mx400exer
Mar 14, 2001 05:08 PM
mhiggins36
Mar 1, 2001 02:00 PM
Robby440ex
Jan 30, 2001 05:09 PM
Robby440ex
Jan 29, 2001 11:16 PM
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
