12v. accessory wire for winch install
I'll be installing a Ramsey winch on my '05 400 4X4 Auto this evening and need to identify which ignition accessory wire is the right one to connect to. I need to identify a 12v. wire that's hot only when the key is in the on position. Was wondering also if there is an accessory wire that is already available with a spade connector, or will I need to splice into one? Am going to try the wireless remote model - I hope it's not more trouble than it's worth! [img]i/expressions/face-icon-small-happy.gif[/img]
Thanks for your reply Bear. Do you by chance know if that particular wire is identified by a specific color? Maybe red with a white stripe or something? If it's not identified, I'll dig out the tester and find it... if I can find the tester since we moved! [img]i/expressions/face-icon-small-smile.gif[/img] Thanks again Bear.
It is a 2 pin plug, one male, ground and a black wire and a female, 12 volts and red. The plug is usually black and your winch harness should have a plug just the opposite so you can plug then together. At least mine did.
Yup - that's exactly where it was, but they sure didn't leave me a lot of wire length to work with. I had a heck of a time getting my big ol' clubs in there to make the connection, but finnaly got it done! Thanks to both of you for your help.
