12v. accessory wire for winch install
Old Nov 11, 2005 | 04:01 PM
mag92803's Avatar
Default 12v. accessory wire for winch install
I'll be installing a Ramsey winch on my '05 400 4X4 Auto this evening and need to identify which ignition accessory wire is the right one to connect to. I need to identify a 12v. wire that's hot only when the key is in the on position. Was wondering also if there is an accessory wire that is already available with a spade connector, or will I need to splice into one? Am going to try the wireless remote model - I hope it's not more trouble than it's worth! [img]i/expressions/face-icon-small-happy.gif[/img]
Old Nov 11, 2005 | 06:38 PM
Bear4570's Avatar
Its in the harness running across top of the engine next to the starter behind the cylinder. Its fairly well stuffed under the harness.
Old Nov 12, 2005 | 12:19 AM
mag92803's Avatar
Thanks for your reply Bear. Do you by chance know if that particular wire is identified by a specific color? Maybe red with a white stripe or something? If it's not identified, I'll dig out the tester and find it... if I can find the tester since we moved! [img]i/expressions/face-icon-small-smile.gif[/img] Thanks again Bear.
Old Nov 12, 2005 | 03:00 AM
Bear4570's Avatar
It is a 2 pin plug, one male, ground and a black wire and a female, 12 volts and red. The plug is usually black and your winch harness should have a plug just the opposite so you can plug then together. At least mine did.
Old Nov 12, 2005 | 11:05 PM
duckdawg's Avatar
mine was located right next the air filter box. like bear says its tucked tight but your winch should plug right in.
Old Nov 14, 2005 | 09:20 AM
mag92803's Avatar
Yup - that's exactly where it was, but they sure didn't leave me a lot of wire length to work with. I had a heck of a time getting my big ol' clubs in there to make the connection, but finnaly got it done! Thanks to both of you for your help.
toonces
Oct 19, 2015 02:21 AM
ScopeZ_
Jul 28, 2015 01:44 AM
Schneider
Jul 24, 2015 05:05 PM
Bratman2
Jul 23, 2015 12:36 PM
cornermike
Jul 8, 2015 11:44 PM
