750CC Trike
Old Nov 14, 2005 | 09:25 PM
kmasine's Avatar
Default 750CC Trike
Here is the latest project. It's a CB750 trike. The frame, front end, and motor off of a '74 Honda CB750 motorcycle and the swingarm, rear end, axle, wheels and tires off of a Honda TRX200sx. It's been re-geared with a smaller engine sprocket and larger rear sprocket to raise the gear ratio. It looks a little rough right now, but it was just finshed rough assembly yesterday. Next will be painting the tank, front fender, and rear plastic. Along with some different wheels and ashphalt tires in the rear because this think will be street legal.
Oh by the way: look up a Honda CB750 4 cylinder. 65 HP stock at the crank at 7500 RPM.
Old Nov 14, 2005 | 10:27 PM
DavidLT250S's Avatar
Default 750CC Trike
any pics?
Old Nov 15, 2005 | 12:57 AM
1bad450r's Avatar
Default 750CC Trike
Post some pics. I would love to see it.
Old Nov 15, 2005 | 05:29 PM
kmasine's Avatar
Default 750CC Trike
I gotta take some more pictures. The ones I took over the weekend were high resolution and above the 150 kb limit on this site.
Old Nov 16, 2005 | 12:44 AM
1bad450r's Avatar
Default 750CC Trike
If you are running windows just you paintbrush to shrink them down. Thats what I had to do.
Old Nov 16, 2005 | 03:35 PM
kmasine's Avatar
Default 750CC Trike
If you want pics I posted them at bikepics.com go to my member page you'll see four of the pics.
750cc Trike
Old Nov 16, 2005 | 05:51 PM
Default 750CC Trike
look like you did a nice job now all you need is a motorcross tire on the front and your set for the trails, how heavy is it?
Old Nov 16, 2005 | 09:44 PM
kmasine's Avatar
Default 750CC Trike
The motorcycle stock was about 500 lbs it's probably touching about 550 now with the rear end and tires. This thing is not for the trails though. It's way too heavy and just doesn't take the tight corners at low speed. It is however a blast to ride on the road. That's why with a set of asphalt tires in the back it will be road ready. It's already got the headlight, and turn signals, all it needs is a tailight/brakelight to be street legal in illinois.
Old Nov 16, 2005 | 10:03 PM
Default 750CC Trike
you should put a enduro head light like off of a klr650 or somthing like that it'll look nicer then that big old circle headlight
thunderpower
KTM
22
Oct 14, 2001 12:00 AM
waco4whlr
May 10, 2001 10:33 AM
fourlix
Mar 25, 2001 12:07 AM
yam8
Jul 16, 2000 03:17 PM
