just got my Rancher AT
Old Nov 27, 2005 | 06:16 PM
HR's Avatar
HR
Default just got my Rancher AT
Ok all you Rancher AT people out there.
what are the things i need to work on for this.. is there a way to rais the RPM at witch the tranny starts to go for more low end power.?
any problems with these?
any info would be great..
i'm looking at the TSL Swamp Lite tires in a 25 would that hurt me to much.???
thank you.
HR
Old Nov 27, 2005 | 08:36 PM
markdb420's Avatar
On a Rancher AT make sure that the ECM has been reprogrammed. When I got mine it wouldn't go over 35 mph and that is because it wouldn't shift correctly. It was a slug on take off. It now can ride wheelies. It also pulls stuff alot better. Mechanic said almost all have the same bad programming in the ECM.
Old Nov 27, 2005 | 10:02 PM
HR's Avatar
HR
so i should take it to the local dealer and ask them to reprogram the ECM?
i have an 04. and there is no way in hell mine will do a wheelie. it does top out at 51 mph on flat ground here at 7000 feet.
i'dd like more info on the ECM thing if you could please.
HR
Old Nov 27, 2005 | 10:12 PM
markdb420's Avatar
Well mine was sluggish starting off in Automatic and went better in ESP mode, but always sounded like it was starting out in 2nd gear. Mine would run in auto or ESP mode only about 35 mph and it sounded as though it was redlining. It was only shifting up to 3rd or 4th gear. My dealer said that not all of the 04 rancher ATs have this problem. You need to have them check it out. I had them check it out when I took it back for the tierod recall. Make sure you have the replacement tie rods put on. Mine were fine but they have had some separation issues on the original tie rods.
vandammages@gmail.com
Aug 20, 2020 11:50 AM
Johnny Mac
Aug 15, 2019 03:13 PM
Clint Russell
Sep 25, 2015 03:20 PM
rgjackson
Sep 17, 2015 11:21 AM
Elkaholic
Sep 6, 2015 02:44 PM
