Lighten a Warrior Flywheel
Old Dec 7, 2005 | 08:50 PM
DriverDoyle's Avatar
Default Lighten a Warrior Flywheel
I Was told if you shave some weight off the flywheel you can gain a little power. So i want to know the DOES and DONTS of doing this. Thanks
Old Dec 7, 2005 | 10:23 PM
Anyone?
Old Dec 7, 2005 | 11:27 PM
IdahoVinnie's Avatar
Technically, you don't gain power, but by reducing the rotating mass, you will have better throttle response (which feels like more power).
Good thing to do? Yes, as long as you don't weaken the flywheel too much to cause a failure of the flywheel.
hondarulesinnc's Avatar
I belive you only has to buy a new one because if you take to your flywheel with a grinder or anything else and don't get it perfectly ballanced bad things will happen. A lighter flywheel will allow your engine to rev quicker because there will be less rotating mass so it might give you a sportier feel. But make sure you do your research.
Hope this helps.
Old Dec 8, 2005 | 12:24 AM
In are quad shop we have a Lave. and we have someone that knows how to use it verywell. how much do you think we should take off.
Joe454
Nov 20, 2020 01:19 PM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
Scooter's Shop
Oct 9, 2015 02:09 PM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
