reverse revlimiter
Old Dec 11, 2005 | 03:58 PM
TheTurtle's Avatar
Default reverse revlimiter
im thinking about getting a 660R (sorry honda). and i was wondering what the reverse revlimiter was like and if it is possible to bypass it like the kfx/z400 by switching some wires around??
Old Dec 11, 2005 | 04:07 PM
maddog56's Avatar
A very simple and fast procedure, just splice a wire and ground it out.
Old Dec 11, 2005 | 04:19 PM
TheTurtle's Avatar
thanks maddog, thats just what i wanted to hear.
Old Dec 11, 2005 | 04:32 PM
themadwarriorrider's Avatar
this is how i by passed my rev limiter on my 04 raptor 660
raptor tranny.com has a diagram for you
but this is what i did, i bought a 100ohm resistor from radio shack for $2.00 and a sodering iron
i disconected the battery and cut some of the black tape so i could access the wiring harness, located the green/tan striped wire, and connected the resistor to it by soldering it in, then i located the thin black wire next to it and soldered the resistor to it, now i don't have a reverse rev limiter and my reverse light still works when i engage reverse, the raptor tranny.com says your reverse light won't work but mine still does how i did it,
i have not had any problem with this set up, i installed it back in october and have been riding quite a bit, no problems
Old Dec 12, 2005 | 01:01 AM
lrb's Avatar
lrb
check out www.sandwizards.com,when u go to their site ,in the left column will be tips&tricks.pick ur model then it will be under reverse rev limit disconnect.awsome pics and very detailed instuctions!!!
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
poutlaw525
Sep 9, 2015 03:19 AM
